- 23 Nov 2018
Hi Guys, first time poster long time reader.
After many years I decided to build a new system and buy a new case, Lian Li PC-7HA (A is silver).
I have a question regarding the operation of the Power Switch button. When the button is pressed on this case, it does not make a click noise (the reset button does make a click sound when pressed)
On my previous Lian Li case PC-7 Plus II, when the power button is pressed (much like the reset button), it makes a click sound.
I was wondering if owners of newer Lian Li cases could tell me whether this is normal ie has the operation of the power switch been changed resulting in no clicking noise.
I built my current system using a cheap Corsair case and wanted to move everything over but am concerned about this since as you all know moving from one case to another is a lengthy process and I don't want to discover that the Power Switch on the PC-7HA case is malfunctioning / broken.
Many thanks for any info provided
Cheers
Cheers
