Lian Li PC-9F
25 Aug 2006
What do you guys think of the Lian Li PC-9F?
I don't quite get it. Can't find anywhere to order one. Overclockers.co.uk isn't stocking it either (atm). Can't find any reviews to double check that it's what I want.
Anyone own one or know of a good review for it?
Before I even begin my build, I'm still stuck trying to find the perfect case.
I got the PC-8FIB, air cooling is not so great if you're planning to OC.
What about if you used Corsair Hydro Series H70?
I think the PC-9F is pretty much the same as the PC-8FIB in terms of structure. Maybe it's the fans not being good enough?
I replaced the 2 front lian li's fans with the 2 akasa apache fans and a fractal design 140mm fan to the top for exhaust.
I was interested in the one OCuk have until I saw the front of that case the OP posted.
The front looks so much nicer!
I'm pleased with my PC-9F. It's a pity that Overclockers don't offer this case.
I chose this case as the intake filters are located behind the case front, so don't show the dust build up as much as the PC-8FIB.
Internally, it is very similar, but does not have the quick release retention mechanism for the pci slots that I believe the PC-8FIB uses.
