lian li pc A05B
22 Sep 2005
Just a few questions about this case because i'm planning to buy it (when OC finally order enough of them to meet demand that is!). Firstly, what's the finish like, quality wise? My last case was a crappy samurai and particularly the front was crappy plastic. Is the removable front bezel of the a05b metal or plastic? Also are there any realy problems with the case? And finally, is it worth the money? Cheers.
finish on the case is absolutely fantastic, and the whole of the front panel is ali not plastic. Also the extra £10 for the matching cd drive cover finishes it off nicely.
My cpu temperature is really good as it has a 120mm fan blowing onto it.
BUT, i have a big problem, its causing my psu to get very very hot, the exhuast fan on the front shares the same air space as the exhuast for the psu. So its restricting the airflow out of the psu.
have a look here:
http://forums.overclockers.co.uk/showthread.php?t=17721204
