Lian Li PC-A05NB
18 Oct 2002
Leeds
Well what a great compact case it really is :)
Specs
Asus P8P67-M PRO
Intel Core i5-2500K
Corsair Hydro H50-1
OCZ Special OPS 4GB PC3-12800C8
Corsair Professional Series™ Gold AX850 High Performance 850W
EVGA 470gtx
Crucial RealSSD C300 64GB
Seagate Momentus XT 500GB Hybrid
Samsung SH-B123L/BSBP 12x BluRay
Got the modded top to support a 140mm fan and plexiglass the side window :)
pmk24
Sorry for a bump, what did you do to remove the hard drive caddies? Could you unscrew them from the front?
I have this case, yes removing the cage is an easy job of unscrewing from the front panel :)
Ah great stuff, thank you, and as for the drive bay under the two 5.25" bays, could I use a 3.5" to 2.5" converter to put an SSD in there? :)
