lian li pc-a10 8800 GTX fit?
BFG_9000 said:
Better with Akasa Eclipse 62.
good suggestion, only im looking for a full tower, and im set on the pc-a10, just need to know if anyone has clarification if the GTX's will have anough room.
thanks ags
Get silverstone TJ-09 if you insist on having a full tower. The case should be able to fit anything you throw in it.
thanks but no thanks... lol
so does no one know the answer to my original question?
ags
The A10 is barely any bigger mate,
Do you really need more than 4 5.25 bays?
Personally I don't think the a10 has many advantages over the Eclipse
Well if you did a search on G80 and case it would reveal the following thread :
http://forums.overclockers.co.uk/showthread.php?t=17650375&highlight=G80+Case
where they reference this link
http://www.tosk.co.uk/8800/
For the A10 it says you can't use a hard drive in line with the 8800GTX card. Now there are no hard drive bays located at the same level as the card, so I take this to mean you just can't fill that 5.25" bay with say an optical if you are using an 8800GTX. Considering there are 6x5.25" bays in this case I don't think it's an issue.
So to answer your question - you can fit an 8800GTX but I imagine it is a tight fit. Also this case is a tight fit for a Scythe Ninja in case you are planning to use that, and the jury is out on whether you can fit a Tuniq without removing the top intake fan.
The Akasa Mirage/Eclipse or Silverstone TJ09 would offer you more room on the cpu cooler department, and also fitting G80's. Piles more room.
<edit>Just read you are looking for a full tower - what about the Lian Li G70. This will definitely take an 8800GTX with ease and supports up to 2 PSU's</edit>
