Lian Li PC-A10B questions.
Caporegime
6 Dec 2005
Birmingham
Anybody have this case? Some pictures would be nice please if you do?
Where are the watercooling holes? On the back or on the top?
Is it all aluminium?
What is the middle lower compartment for? (see picture)
Im undecided between this and the V2000. Really really like the look of this case more than the V2000, black by the way everything has to be black :).
Cheers guy and gals.
Azza
The middle section is for two 3.5 harddrives and the section to the right of it takes 3 harddrives...
and it has watercooling hole in the top...
It may have them at the rear as well.)(i can't remember)
(P.S Azza check your e-mail :) )
great case, all the bits that i can tell are Aluminium, water holes are in the top, and the cooling is first rate.
sexy looking, solid door, and i cant really find a fault to it. Routing is pretty easiy, though you may well need an extra extension lead if your Mobo runs of a 8pin rather than a 4pin power conector, but that is the only niggle i had.
I was torn between this and the Silverstone TJ09... however I ended up going for the TJ09 and don't regret it for a second, I much prefer the layout/design. The Lian Li is a lovely case though. :)
Thanks a lot for your answers guys and thanks for the review links chaparral.
Think I have found my new case. :)
