is there any other differences on these apart from the hot swop sata?(from the 71
None that I can see from the pic, except of course the case has beveled front edges and I expect the top panel has eSATA..
See thats what worries my about lian li cases, I wouldnt mine paying £120ish for a case with thin sides but when you pay £200 you dont want a thin rattly case. The Zalman cases have panels which are like 5mm thick![]()
I expect Lian-li will argue that people will then complain about the added weight if they are 5mm so they cannot win.
Yeah 5mm is over the top but there is a middle ground. Dont really understand the issue with weight tbh its not like you ride it up a hill. And i'd wager the majority of lian li owners don't LAN
Now why should quality maker copy case to which Safety Technology Authority gave withdraw from sale recommendation because of failing EMC?but I would have loved Lian li if the copied the Eclipse 62
5mm aluminum is already heavier than 1mm of steel so not much sense in it. (except in some support structures of case)The Zalman cases have panels which are like 5mm thick![]()
While new front intake probably has lower airflow impedance plasticky HDD mounting is considerably worser from noise aspect than soft mounting.Agreed.
I simply am very happy with my A70B, but there is always a middle ground and room for improvement and the PC-A7010 looks a step in the right direction.
Just to point out, I've seen both of these cases at other UK stores. OcUK due dates/prices? A77 too.
the only thing ive noticed is the a71 has holes in the door to vent air to the 2 intake fans, this one doesnt seem to?
"Thank you for your webnote. Unfortunately we currently do not plan on stocking this item.
Regards,
Martin Roberts"
-Overclockers.co.uk
Probably depends on whether theres enough demand.
