Lian Li PC-B20A
12 Apr 2007
Hi, I'm currently putting together a PC, but due to money constraints Im going to have to build it over 4 months...so I'm starting with the bits that I'm less likely to change my mind about if/when new parts come available.
I really like the looks of this case, but if anyone can answer some questions regarding size, I would be grateful.
I'm looking to fit a standard 8800GTX, will this fit?
Also, the CPU cooler I'm looking at is the Thermalright ultra 120 extreme, anyone know if this will fit?
I'm also looking at replacing the 2 120mm fans with 120mm Noctua Items, and If there is room, another Noctua 120mm attached to the Thermalright, and replacing the 80mm intake fan with, you guessed it, another Noctua 120mm, but used as an exhaust.
anyone know if I can squeeze all this in? :D
Ive read some reviews but they don't seem to touch on how much room there is in there, any advice appreciated, Cheers
well from the looks of it, it seems to have around about the same amount of room as a pc-7+ (same interior beside the hhd bay facing the other way)
so i'm just going to give you answers purely based on what the pc-7+ can fit.
the pc-7+ can fit a gtx but it just touches the hdd cage so you cannot fit a hdd in one slot, but saying they're turned around i would hope it does.
also yes the thermalright u120 should fit in and be able to fit a fan.
someone back me up here
