- 8 Jan 2019
- MSI HQ
Landing at the end of the month, the long awaited Lian-Li PC-O11 DYNAMIC XL ROG Certified Case is now available for preorder! Available in Black or White flavours, the Dynamic XL builds on the immensely popular PC-O11D case by adding a slew of requested features from end user feedback, including thicker radiator support at the bottom of the chassis, aluminium front and right side panels, ARGB front LED strip, 1 x USB3.1 Type-C and 4 x USB3.0 on the front panel, space for E-ATX motherboards (including the huge Asus ROG Dominus Extreme with the addition of a bracket sold separately), hot swap 3.5" bays, space for 6 x 2.5" drives and much more. There's space for 3 x 360mm radiators at the same time, 446mm VGA cards and there's space for up to 10 x 120mm fans. The ARGB strip is fully Asus ROG certified, although compatibility with MSI/Gigabyte/Asrock compatibility is also possible. CPU Coolers up to 167mm are supported as standard, along with 210mm ATX power supplies.
All in all, the PC-O11 Dynamic XL Chassis from Lian-Li represents a nice upgrade over the existing PC-O11D, giving you more freedom to build a monster watercooled build whilst providing more features than you can shake a stick at. Stock is due to arrive at the end of the month and I expect that initial quantities will be snapped up quickly, so order quickly if you want to be in the first batch!
Lian Li O11 Dynamic XL (ROG Certified) Aluminium Midi-Tower - Black @ £199.99 inc VAT https://www.overclockers.co.uk/lian...ied-aluminium-midi-tower-black-ca-77k-ll.html
Huge Dual-Chamber Midi-Tower, Side- and front in tempered glass, Graphics cards up to 446 mm, 3x 360 mm radiators compatible, Roof and side in aluminium, Up to 9x 120 mm fans, 1x USB Type C + 4 x USB3
Only £199.99 inc VAT.
ORDER NOW
Lian Li O11 Dynamic XL (ROG Certified) Aluminium Midi-Tower - White @ £199.99 inc VAT https://www.overclockers.co.uk/lian...ied-aluminium-midi-tower-white-ca-77l-ll.html
Huge Dual-Chamber Midi-Tower, Side- and front in tempered glass, Graphics cards up to 446 mm, 3x 360 mm radiators compatible, Roof and side in aluminium, Up to 9x 120 mm fans, 1x USB Type C + 4x USB3
ORDER NOW
ORDER NOW
ORDER NOW
