LIAN LI PC-Q08 USB3.0 MINI-ITX CASES (RED AND BLACK) - PRE ORDER NOW
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Lian Li PC-Q08B USB3.0 Mini-ITX Case - Red @ £104.99 inc VAT
Mini-Q PC-Q08 is made in Taiwan, with the highest quality aluminum alloy panel. The Mini-Q PC-Q08 carries the standard of Lian Li’s quality requirement, all the sharp edges had been removed to protect user’s hand. The chassis is made of 1.5mm aluminum alloy panel to ensure product’s durability and all external parts are hair-line brush anodized aluminum in keeping with Lian Li’s classical style. The clean shape of Mini-Q PC-Q08 with rounded edge can be fit with interior decoration easily. The hair-lined anodized aluminum exterior dress up with blue and red back-lighted power and reset buttons. The design of Mini-Q PC-Q08 is to be as simple as possible, the exterior of the case is also the structure of the chassis. To ensure you can put everything together easily, Lian Li design team decided to use only standard PC component inside the Mini-Q PC-O08, standard Mini-ITX motherboard, standard 5.25” optical drive, standard 3.5” hard drives, standard ATX PS/2 power supply units and standard graphics card.
- Dimensions: (W) 227mm x (H) 272mm x (D) 345mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay (External): 1
- 3.5" drive bay (Internal): 6
- Expansion Slot: 2
- Motherboard: Mini-ITX / Mini-DTX
- System Fan (Front): Black, Silver / 140mm Red LED Fan x 1
- System Fan (Top): Black, Silver / 120mm Red LED Fan x 1
- I/O Ports: USB3.0 x 2 / HD Audio
- Maximum Video Card Size: 300mm
Only £104.99 inc VAT.
ORDER NOW
Lian Li PC-Q08B USB3.0 Mini-ITX Case - Black @ £92.99 inc VAT
- Expansion Slot: 2
- System Fan (Front): Black, Silver / 140mm Blue LED Fan x 1
- System Fan (Top): Black, Silver / 120mm Fan x 1
Only £92.99 inc VAT.
ORDER NOW
Are USB 3 sockets physically different to existing USB2 ones? If not would all existing case mounted USB ports be 3.0 compatible?
USB3.0 is backwards compatible in that USB2.0 devices will work with them, but max's out at USB2.0 speeds.
An older USB2.0 case header would not work up to USB3.0 speeds.
It's all about future proofing.
Ace, will you be able to get information about what cpu coolers will fit when they come in stock? also if an h50 will fit in the roof?
