lian li pc q08
11 Jan 2005
Birmingham
Just seen this little beauty!
Comes in black, red or silver.
Model PC-Q08
Case Type Mini Tower
Dimensions (W) 227mm x (H) 272mm x (D) 345mm
Front bezel Material Aluminum
Color Black / Silver / Red
Side Panel Aluminum
Body Material Aluminum
Net Weight 2.73KG
5.25" drive bay (External) 1
3.5" drive bay (External) none
3.5" drive bay (Internal) 6
Expansion Slot 2
Motherboard Mini-ITX
System Fan (Front) Black, Silver / 140mm Blue LED Fan x 1
Red / 140mm Red LED Fan x 1
System Fan (Top) Black, Silver / 120mm Fan x 1
Red / 120mm Red LED Fan x 1
System Fan (Rear) none
I/O Ports USB3.0 x 2 / HD+AC97 Audio
Maximum Video Card Size 300mm
Package Dimensions (W) 279mm x (H) 333mm x (D) 407mm
Gross Weight KG
looks to be a stonker of a little case!
A few mods (remove front fan) would allot for a longer gfx card (5870...)
Top vent allows for a corsair h50?
Bottom vents allow for gfx card air flow (coupled with the psu as an exhaust)
hdd could be placed in the cd drive bay if you use a slimline drive instead making more room in the case.
Or, could probably fit a 240mm rad in the top? If you wanted to go really crazy, remove the hdd cages and you have a place for a pump. Stick a slimline drive in the bottom of the drive bay. and mount a hdd (large size laptop hdd?) underneath it.
Oh, and it looks Stunning! It's exactly what I want as a massive fan of the v-range/drilled hole look.
Hello high end, i7 rig <3
I hope its a month or so, birthday time for me :D
Hoping the DFI or Zotac itx boards go down in price a little by then aswell but i'm doubting it. Should be able to fit my whole current rig in it without losing any performance :cool:
hhmmm this may actually meet my needs lol, I assume it's not very wide but really tall. I have no height restriction but maybe limited in width.
Would my GTX260 fit in one of these?
It fitsa 30cm card so yeah easily. It's not that tall at all, look at the specs :p
It certainly will dwarf my mates shuttle, but this would be upgradable and could take pretty much any G card I ever wanted.
Now to source an AMD Mini-itx board as I wanna keep my P2 965 if I can.
Theres only this one isn't there: Sapphire IPC-AM3DD785G
Rarer than hens teeth :/
Just a bit scared about the 125w of the cpu and heat. Although it ddoesn't run hot in my tower.
x58 shuttle:
Length: 325mm
Wideth 208mm
Height: 189mm
lian li
(D) 345mm
(W) 227mm
(H) 272mm
not thatttt much bigger, still desktop sized :D I really cant wait for it to come in the uk now!
the new shuttle can also take mitx boards, but, youll have to pay through your arse for an x58 itx system imo.
x58 shuttle:
Length: 325mm
Wideth 208mm
Height: 189mm
lian li
(D) 345mm
(W) 227mm
(H) 272mm
hhmmm I take it back, the pictures make it look bigger without a reference lol.
It's like a more practical shuttle hehe
How would a massive psu fit in?
perfectly, its designed for standard atx psu. I'll be using my corsair 620 modular.
(and a gtx 280 gfx card btw, ill upgrade it at somepoint as im thinking without a front fan itll take around a 33cm card)
for ref, the front fan is 140mm, and the top fan is 120mm
