Lian Li PC-Q25
4 Sep 2006
Bristol
Seems like Lian-Li have the annoying habit of making decent cases, but with small problems that put me off buying one. :(
Liking the hot-swap bays - keeps wiring to a minimum, especially if folk don't mind chopping up their PSU cables/making custom ones.
Apparently the V353 comes with no fans, which knowing that it'll be expensive, seems a bit stingy.
I like it a lot, but I love have Lian-Li always go for the clean finish then they go spoil it with a grill at the top. Not even directly in the middle its always off centred to a degree
Just finished putting my rig in my new C50 and go to say it looks so clean. No fans in the front, only the USB, audio, power and the bezel for the optical. Love it. Pitty I couldn't get the rad fans inside the case.
Lian Li are on a roll right now, but I just wish they'd figured out the tweaks a year ago.
Looks good buddy,saw the pic of yours ;)
I comtemplated that case for a bit also whilst looking for something more "slimline" than the PC354b.
Only problem is the length of GPU it can take. It says 250mm which is nothing really, I'm going to have to get the tape out though, see if I can get another 10mm or so.
28mm narrower than a Q08, 21mm deeper and 9mm taller.
Still 5L+ bigger than an SG07. I fail to see the appeal?
Looks good this case but dont need all that hard drive space I will use 2 or 3 max in an itx case.
Will stick with sg08 the Fractal Array Mini R2 is too big for me as well.
Takes more hard drives, looks cleaner on the front and with a full size PSU gives more options. Yes I know its bigger, but there is a lot more in there.
As for the comments on the fractual - I'm not sure I'd want one when you read about the cooling and TBH this is a hybrid allowing 5+ HDD and full length GPU. Brilliant for LANs or someone with plenty of data but not wanting a server to store it on.
Doesn't the Q08 take a fair few HDDs anyway? I just fail to see the niche for this product.
