Lian-Li PC V2000 PLUS
4 Oct 2005
Herefordshire
hi guys does this case Lian-Li PC V2000 PLUS Silver Aluminium Full-Tower (No PSU) on the shop come with the clear side panel, in all of the shots of reviews i have looked they all show a windowed side pannel.
any idea please
many thanks
You will have to contact the shop to get the 100% correct answer: http://www.overclockers.co.uk/contact.php
The side panel is offered as an extra after market addon, I have never known a V series or a model in the range to ship with the windowed side panel so it would be a new idea to me.
You can get a +II version that has a section of the side panel meshed for the blower / extraction fan on the side.
thankyou, its a real pain when these sites do reviews they review it with the "extras" and dont say they are extra, so i would be looking at an extra £30-£45 jsut for the side pannel.
thank you for the swift response
It can be slightly annoying.
I take case reviews with a pinch of salt, rarely they do anything but praise the case and often their criticisms are due to them not giving enough thought to what the case designers intended when they actually designed the case.
I would get in contact with the shop to check what stock they have, but as far as I am aware there is no windowed version as an 'all in one'.
Windows side panel for the V2000 is Lian Li Part Number WV2000 for silver or WV2000B for Black. Order WV2000PII or WV2000BPII if you have Plus II model.
£55-ish in the UK plus delivery.
lol ouch, times like this i wish i was good with a dremel, but to attack a case like that, wife would kill me.
thank you very much guys for the replies
