Lian Li PC-V2110 review
Here's another review:
http://www.ultimatepc-reviews.co.uk/PDF REVIEWS/LianLiV2110-UltimatePCReviews.pdf
If Lian Li had just included PCI/graphic card exhaust fan cooling should be well enough for dual graphic card configurations. Also changing that mesh of back exhaust fan to normal wire grill would increase cooling (both more airflow and less turbulence noise) and stamped grill on inside is mostly useless extra airflow impedance.
But regardless of that there just aren't any excuses for above 50W heat output graphic cards to not exhaust their heat directly out of the case. Their HSFs practically block use of next expansion card slot in any case so could use that space for something usefull as well.
