Lian-Li PC-V300 + X1950 question
23 May 2004
Which GFX cards fit a Lian-Li PC-V300
will a PowerColor ATI Radeon X1950 Pro Extreme fit in this case with a Abit IP-95 Micro ATX motherboard? the card is 210x100x32 mm. or about 8.25"
Thanks
ST
The simple answer is no.....
... the more complex answer is, yes, aslong as you don't mind cutting into the internals of the case a little. You'd need to cut a gap into the 3.5" floppy cage, which should be a ten minute job if you've got a dremel with cutting discs.
To get by without cutting the slot, you'd need a card below 8 inches in length.
Other than this issue, it's a very very nice case.
I cut mine with a small hacksaw :D Its very easy to get to and infact the bit you'll need to cut into is very small (hard to explain without my emptying the case and putting pictures up).
swiss tony soz for off topic but do you have any relations with a person with the last name of swift
back on topic the sugo is a nice case just remember to get the evo version
The LianLi is much better imo, I've had 2 sugo's (1 evo) and this case. It took me 5 minutes to cut away the bit. On the other hand, I am selling this case to get a nice big ATX SLI mobo/case ;)
