Lian-Li PC-V600 Owners
6 Jan 2006
Ayy
Hi,
was thinking about getting this case to replace my chieftec dragon, just a quick question.
Can the front panel be removed like the PC-7+ so i can install the aluminum bezels?
Cheers
You can not remove the front panel, the V cases are two peice designs so you can't or the whole case would fall apart.
They are compatatble, although I think that WJA96 had to slightly mod his to get them to fit properly which sounds very un-Lian Li like.
Yes - the bezels that were supplied by OcUK needed the lower holes drilled out to fit. They were in the right place, but they were the wrong size.
I would also suggest you invest in some better fans as well, as the supplied Lian Li ones are not the best.
And they were a real pig to fit. They had to be very carefully angled through from the side. I wrapped them in kitchen towel to stop them getting scratched.
