Lian Li PC-V800
deadeyedic30 said:
I was thinking of putting a 7800GT and an Arctic Freezer 64 pro in there. Will need to check them tonight then. :confused:
I've got a Lian Li case where the PSU is mounted over the processor (PC-G50). I've also got a Freezer 7 Pro cooler in another PC, very similar to the 64 Pro. TBH, I don't think theres a chance of the cooler fitting if the PSU is fitted over the socket. You'd need something quite low profile. In my Lian Li case I have an Athlon XP with a Thermalright SLK900 w/92mm fan and its extremely tight (fan is about 1cm from the PSU).
Sounds like i should have gone for the Silverstone case but they are no longer available. Would the Zalman 7000 all copper cpu cooler fit ? :confused:
Or is that even bigger height wise. Currently in my main rig, so could switch coolers if i had too.
The 96mm Zalmans fit. That includes the 7000 and 8000, but you may be able to get away with a 120mm 7700. Actually, looking at the airflow diagram nothing seems to be in the way of the socket, so you may be able to get a Freezer in there if it's under 6".
Are we talking about the same case, he said V800 not V300...
Anything ATX will fit any of the ATX branded form factors bar eATX.
Freezer 7 Pro does not fit. All the Zalman flower types coolers do, the blue and Golden Orbs do (actually it depends on the motherboard - usually they do) and the Silverstone NT-03 fits.
