Lian Li PC60/1
23 Oct 2002
_
I've just bought one and fitted it, and one thing has really griped me; the hard drive cage.
The one right down the bottom. The one you use in conjunction with the adjustable plate to fit the hard drives in. Adjustable plate is a good idea I suppose, but it takes a million screws if you want to take one of the hard drives out!
I decided instead to put it in one of the slots in the cage above for 3.5" devices, and realised you can't have a hard drive and a backing plate in the same slot as it won't fit!
I can't believe nobody's mentioned this before, as it seems like a pretty stupid idea.
Either that or I've fitted the case wrong. :D
Did anybody else think this?
