I'd say they are mid range, not ultra quiet. Depends what you're used to. I replaced mine with some silenx ones when i got it, made a hell of a difference!
But the draw of 120mm front and 120mm back gives quieter and cooler performance, add to that its cheaper and how most modern CPU coolers wont work with a motherboard tray and the PC7+II does become more attractive.
why do most modern cpu coolers not work with a motherboard tray? dont see how that can be true as ive had cases with mobo trays for years and they havent had any kind of problem mounting large thermalright heatsinks.
(OCUK site says the PC7 comes with 1 12cm and 1 8cm)
