Lian-Li PC60 Plus cooling & noise
19 Nov 2006
Barton Upon Humber/Whitby/Scarborough
Having just changed my case from a Coolamaster, my temps have dropped dramatically from ~49 - 51 to ~36 - 37 (TAT). :D
Was wondering if I could drop them any more by employing different fans.
At the moment I still have the same 12cm ones as supplied with the case, but I did change the two 8cm ones for Sharkoon 1000's.
What would you suggest? I have ordered a couple of YATE LOON 120mm - D12SL-12 UV Blue Frame with 4 Blue LEDS, that had been suggested, but are there others that would lower or at leat keep the temps as they are but work quieter?
