Lian-Li PC61 at OcUK
18 Jun 2005
I see that the Lian-Li PC61 is being advertised with a 120mm fan. The only reference I can find to this case anywhere on the web with a 120mm fan is the Lian-Li PC61 PlusII model which has a 120mm intake, an 80mm rear fan with cpu air duct, and also a side grille/fan for video cooling. Wondering if anyone knows for sure what model OcUK are stocking ?
OcUK will know for sure, if you check the News on the site it gives you a the opening times.
Phone them up, they will know what they have in stock :)
Also; why not just get the better case that is cheaper, the PC7+II/PC007. A better case for cheaper :D
Yeah...I already ordered a PC7 from OcUK during the week. Should be here soon...A friend was asking about a Lian-Li with a removable mobo tray. It seems to me the PC-60 plus OcUK sell is superior to the PC7. Removable tray, handy attachment for power switch,power led's etc, 2x120mm fans,cpu duct, psu duct, 80mm top fan and pci blower as standard. Costs an extra 25 quid on top of the PC-7.
<edit> Actually the advertising on OcUK's site is wrong. They say 2x120mm fans, and a 120mm blower fan. Well the rear fan in the PC-60 plus is an 80mm fan and comes with the cpu duct, not a 120mm fan as advertised. The PC-7 looks more attractive allright. Out of curiousity are the fans in the PC-7 4pin or 3pin, as I might need to buy 4 pin to 3pin adaptors if I decide to run if off a fan controller. Also, I am wondering has anyone tried a 4pin to 3pin adaptor & Fan Controller on the optional pci blower fan as I hear it's noisy </edit>
I actually find ambers too noisy myself. And SilentX push hardly any air. About the best ones I have come across are Nexus. Despite their 22db rating they are quieter then ambers, but seem to push less air then the ambers. I want to be able to run my fans at 12v when gaming and 5v or possibly turn some of them off when not. Also wondering what the best fan controller is. Some of them can only dial a fan up as high as 8 or 9v (Zalman), some use pwm which causes clicking in a lot of fans (Silverstone).
Thinking along the same lines myself.
Out of curiousity what are the odds I end up with blue led fan on my PC-7 (or 007) when it arrives. And are they quiet ?
