Lian Li PC7+, blue leds for it, which ones?
21 Oct 2002
Bexhill on sea
As title. I've just ordered a Black PC7+ and I'd like to fit a coupla blue leds to the front in place of the green and amber ones. trouble is, I don't know what type to go for. I don't want ultra bright ones, just the same intensity as the original (standard?) ones. Theres a thread running here where a guy has asked the same question, but I reckon its got lost at the bottom of the page.
Can anyone point me in the right direction please.
Cheers.
I also can't find any leds here at all on ocuk. :confused:
I'm sure you can find some at your local store of some kind. I've used some really cheap blue ones for my PC7 for over a year, no problem. Picked up the first I found, believe it was 3.3V(but they manage 5V without any problems). Simply cut off the old ones and solder on the new ;)
