Lian Li PC7 & Silverstone Control
17 Sep 2005
Everywhere
Hey,
I recently bought the Lian Li PC7 in black and the Silverstone SST-FP52 lcd display thing.
I am having problems fitting it. The Silverstone just doesnt fit properly - looks rubbish. The screws dont fit very well. Id say its about 1/2 Inch short to fit the 5 1/2 bay. Does anyone else have those products and have the same problem? It just looks terrible - very annoyed.
Try taking it out and putting it back in again. When I put my ROMs into my PC-7 originally, when I tightened the screws I found them being pulled to a side. If this is the same problem you're having, you just have to be gentle with the screws, tightening them evenly until the front sits flush.
