Lian Li PC7 stock fans
28 Feb 2004
A few weeks ago i got the lian li pc7 i use the stock LED fans that came with it but recently the LED keeps going on and off anyone else had this problem? If they are close to breaking what 120mm fans are good to keep the case cool and relativly quiet
Not had any problems myself.
Get the 120mm Akasa Ambers.
7v them if you want perfection in silence ;)
Either your PSU is dipping the power, or the fans are on the way out / just a bit faulty.
I would just switch them to some ambers.
