Hi All
This is my first post so be gentle
I’ve got a Lian-Li PC70 on the way I hope!!! (looks like a bad choice of online shop
) I know there are newer ones out there but that’s the one I’ve gone for. I want to mod it a bit ,I’ve already got a triple uv laser, blue bulgin anti vandal switch, and have a custom etched window kit(on its way from the States) will maybe put a window on the top of the case too. I’ve trawled the net but got a few questions. Does it come with a blow hole on the top? Is it best to replace the fans it ships with (with ambers maybe)? And do you have to mount your psu upside down (which is an Enermax Liberty 500w) because of the shelf below the psu?
Thanks
) I know there are newer ones out there but that’s the one I’ve gone for. I want to mod it a bit ,I’ve already got a triple uv laser, blue bulgin anti vandal switch, and have a custom etched window kit(on its way from the States) will maybe put a window on the top of the case too. I’ve trawled the net but got a few questions. Does it come with a blow hole on the top? Is it best to replace the fans it ships with (with ambers maybe)? And do you have to mount your psu upside down (which is an Enermax Liberty 500w) because of the shelf below the psu?Thanks
so hopefully the order will fall through and i can add the xtra
smallprint, wouldn't mind losing a tenner but £50
