Lian Li power button led swap - need help!
21 Dec 2005
Lian Li uses the same Power button for the PC-V351/ PC-Q06 etc...
Does Anyone know or tried to swap the blue led on the power button of this. I've taken the power switch apart but not sure where to desolder and take the little LED out.
If anyone can help me it would be appreciated as I've already kind of damaged the switch case trying to get to the LED. I just want to swap out the blue for a nice white LED.
Are those switches or those LEDs lightning the switches?
Focusing is in wrong place so hard to see what those are.
And can't find anything from Lian Li's new screwed up site to see if there's any good pics of those parts.
It is an LED within the beige coloured switch.
Sorry for the bad photos. The LED is about 2mm and its difficult to focus with my phone cam.
So that white part is the moving part of switch?
Looks like LED's legs might be "above" whole switch and reach to rear from sides, like that one going to green wire.
(instead of LED being inside switch in its center)
If those holes for LED's legs are loose then it would be easy to replace it.
But if LED's legs are molded into that black plastic frame then it would be harder.
