Lian li power button problem
3 Apr 2007
South of the Watford Gap!
Anybody with a lian li case have problems with their power button, recently with my case you have to hit the button 5-6 times before the PC will start up, am wondering if dust has somehow got in and foobared it or what else to look for or try to fix the problem.
Measure the hole in the case.
Was hoping somebody knew the diameter as I really didn't want to pull the case apart without having the replacement part to fit. :) Think I'll pull it apart in the morrow and have a look at the switch.
It will fit right in the stock hole but you do have to cut away part of the front inside panel to get it to fit.
