Hello,
In this project I am trying to squeeze an i7 5820K, EK Predator 240 and a triple slot graphics card into a Lian Li PC Q37WX ITX case. The GTX 970 Hall of Fame will be used since I am still waiting for VEGA.
The specs:
1. CPU i7 5820K @ 4.5Ghz 1.22v
2. Mobo Asrock X99 ITX
3. Avexir Raiden series 2x8GB 2666Mhz
4. VGA Galax GTX 970 HOF (temporary)
5. Corsair SF600
6. Samsung 950 Pro 512GB
I was so excited and eager to start so forgot to take pictures of the case itself. So here is a image from the web.
The parts:
I lost the I/O shield somewhere which is pretty annoying
The EK Predator 240 is big but this case says no problem.
Took me a few hours, 90% complete.
So far a few problems arised:
1. The coolant colour isn't exactly what I wanted. It is Mayhems X1 UV Clear Blue but the blue is pretty much nonexistent. This will be changed.
2. The CPU was running fine at 4.5Ghz with adaptive voltage of 1.22v for the past 8 months now it refuses to work at any kind of flexible voltage. It seems only work when I set a fixed 1.22v at 4.5Ghz.
3. The I/O shield.
4. The graphics card is too tall I can't put the side glass panel back in
. VEGA please come soon!
Thanks for reading!
The specs:
5. Corsair SF600
The parts:
3. The I/O shield.
Thanks for reading!
