LIAN LI RANGE OF ACCESSORIES - PRE-ORDER NOW
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Lian Li and OcUK have teamed up to offer a great range of accessories to enhance you computing experience. With Hard Drive Enclosures, Fan Controllers all the way through to Gamiung Surfaces. There surely is something for everyone in the range.
[url=http://www.overclockers.co.uk/search_results.php?sortby=priceAsc&groupid=&search=lian2404]CLICK HERE FOR FULL LIST[/URL]
Alternatively here are a few highlights.
Lian Li EX-33R1 3 x 3.5" Internal Hard Drive Cage - Red @ £30.98 inc VAT
Add an extra three 3.5" drive bays into your chassis using your redundant 5.25" bays, with the high quality patented anti-vibration kits already pre-fitted your drives will be near silent when in operation.
- 3 x 3.5” HDD extension Cage
- 1 x 120mm ball bearing fan (1000RPM)
- HDD mounting with Lian Li patented anti-vibration kit
- HDD cage gate to secure the HDDs.
- Dimensions:149mm (W) x 129mm (H) x 193mm (D)
Only £30.98 inc VAT.
ORDER NOW
Lian Li EX-20 SATA Hot Swap 2 Drive HDD Enclosure @ £88.99 inc VAT
Run out of space within your computer case? Now the answer is here with the dual bay, raid enabled Hot Swap Hard Drive Enclosure. With looks to die for this is the only option for increasing your data storage capabilities.
- HDD Type: 3.5" SATA
- HDD Amount: 2
- Interface: USB 2.0 (480Mb/s), e-SATA (3 Gbps, auto-negotiates to 1.5 Gbps)
- Raid Controller: Silicon Image™ SiI5744
- Raid Mode: BIG / JBOD / RAID-0(FAST) / RAID-1(SAFE , SAFE 33 , SAFE 50)
- Features:Hot Swap, Plug and play functionality
- Supports 1.5TB RAID drive, maximum 3TB
- Automatic disk rebuild (when one or more RAID 1(SAFE) volumes are configured)
- No driver, BIOS or software required
- LED status for each HDD
- Dimension: (W)175mm x (H)90mm x (D)260mm
Only £88.99 inc VAT.
ORDER NOW
Lian Li Red 26 LED Light Strip @ £15.99 inc VAT
Jazz up your chassis with this new red LED strip which can be fixed anywhere within your case giving your system a new lease of jazz.
- Red LED Kit
- LED pcs:26
- Length:360mm
Only £15.99 inc VAT.
ORDER NOW
Lian Li EX-553X 5.25" to 3.5" HDD & Slim Optical Drive Bay Converter @ £13.99 inc VAT
This drive bay converter allows you to fit either a slim line optical drive and a 3.5" hard drive or two 2.5" hard drives. Includes the added bonus of a front mounted USB2.0 header to give you even more peripheral support.
- EX-553 ( Aluminum structure ) Using 5.25" Bay x1
- USB Port x 1
- Slim CD-ROM space x 1 & 3.5" HDD space x 1 or 2.5" HDD space x 2
- Dimensions: 145mm (W) x 42mm (H) x 172mm (D)
Only £13.99 inc VAT.
ORDER NOW
Ace Modder, is there any chance of OcUK getting in Lian-Li's Case Carriages? AFAIK, no one in the UK sells these yet, which is strange as they seem like a really good idea, especially if you have a PC that weighs the same as a horse;)
Looks like some nice stuff, wonder if they do the LED's in other colours? :)
And take a look at these images too. They are amazingly good quality. Once you fit your side panel to hide the direct glow these are ace looking inside your system.
I do like the red personally. When stock arrives I'm going to be buying a red one myself. Will go nice inside my Corsair 800D
Are you talking about the case carry handle?
Its good to see some of these back, the internal drive bay cage is handy if only just to add another 120mm intake for my 60b+ II case without having to mod it myself. Will definately pick one of these up when i get the chance.
Great to see this range of products, i bought a Lian Li A70F case from ocuk a few months ago, fancy adding a few bits to it. The stealth drive bezel being one, and possibly a black pcie clamp system.
hiii i'm interested in the q08... but it's in red and most optical drives are black or beige? so do you know where i could get some red covers?? or even a red optical drive?? :)
