I have decided to purchase either a Silverstone or Lian Li case.
My choices have been narrowed down to either:
Silverstone: TJ-07 or TJ09.
or
Lain Li: A16, V1200 plus II, V1000
I currently own an Antec 900 which has become very dusty throughout use (3 months since build), fairly noisy (with the fans on low) and I don't believe it cools my components sufficiently.
I don't have a watercooling setup and don't intend on buying one, it just uses air to cool the components. My spec is below:
QX6700 + Tuniq Tower 120
680i
2GB corsair dominator
8800GTX
Corsair 620w
Antec 900
500GB
I cannot find case temps for the TJ07 so would appreciate if anyone can post theirs.
I chose the cases above due to their size, I read that if there was more room and ventilation in the case it would benefit the temperature of the case. Is this correct?
I have the money for a TJ-07 but most of the people who have them, have watercooling setups. I love the curved design on the TJ-07 but on the Lian Li V series I'm not too keen on the inverted position of the mobo. The TJ07 is more expensive compared to the others so I would need to justify that this is the correct case.
My antec porvided me with lots of problems like if the case was nudged, the computer would switch off, if something was plugged into the back i/0 port, it would switch off, although, i presume there must be a loose connection somewhere which would probably solve this issue.
I must stress that air cooling will be used so the temperature, noise and dust issues are important to me help me with my decision on purchasing the correct case...hopefully within a few days.
Thanks in advance
or
680i
8800GTX
Corsair 620w
Antec 900
500GB
Thanks in advance
