Lian Li SLV2-1 Extended Power Cable Set
10 Jun 2003
Will OcUK be stocking these , if not anyone know where I can find them ?? I intend to get the V3000 Plus but have concerns as I know the fan cable lengths are on the short side ;)
Can't help with your query, but one thing you might like to consider is that the USB 2 header to micro USB cable which comes with the SL V2 fans is really short, 42 cm. Too short for my Lancool III to go from the motherboard USB header, round the back and plug into the controller. There was no slack for cable management, so picked up a 50cm one online.
I can only imagine a V3000 will be more of an issue with the short cable?
I will be using the Lian Li controller which sync`s all the rgb , so yes I expect to have a few headaches regarding the V3000 plus :eek:
