OcUK Staff
- 26 Nov 2014
- Stoke
Today we are happy to launch the new Lian-Li Strimer Plus Addressable RGB 24-Pin and 8-Pin cables at OcUK. The Strimer Plus is an upgrade to the existing Strimer series of cables, offering addressable RGB functionality along with compatibility with 3-Pin ARGB enabled motherboards. The Strimer Plus cables function as a standard 24-Pin/8-Pin extension cable, with the addressable functionality, allowing an array of effects & modes. They can be changed via the bundled controller or by using compatible motherboard software. The end result is a striking addition to your system for those who love RGB.
The Strimers are in stock and ready to ship today, and for a limited time only, the Strimer Plus 24-Pin is available at the price of the original Strimer - £44.99. Place your order today!
Lian-Li Strimer Plus Addressable RGB 24 Pin Motherboard Cable @ £44.99 inc VAT
24 pin power extension cable, addressable RGB illumination, Bundled LED controller, addressable via 3-Pin 5V ARGB header
Only £44.99 inc VAT.
ORDER NOW
Lian-Li Strimer Plus Addressable RGB 8 Pin Motherboard Cable @ £35.99 inc VAT
8 pin power extension cable, addressable RGB illumination, addressable via 3-Pin 5V ARGB header
Only £35.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
