Lian Li Strimmer compatability
26 Nov 2002
Oxford
I'm contemplating getting Lian Li Strimmer cables but was wondering if they can be controlled with my motherboards argb software?
I have an Asrock x570m pro 4 which has one 1 rgb and 1 argb header, using a a lumin s36 argb aio and fractals rbg fans daisy chained together, using Asrocks polycrome software to control the rgb. And using gigabytes software to control the graphics card rgb.
If I add the stimmers into the chain will it work with the software or do I need to use the Lian Li software/control box?
And or will Lian Li's control box conrol my Fractal argbs ?
I would like a 1 stop solution to control them all if possible.
