I've just built a new rig, with Lian-Li TL LCD Fans. See pic here: https://files.slack.com/files-pri/T11G290H4-F08P6Q2HX7T/img_1327.jpg
The problem (as you can see in the pic) is that although the fans are lit, spinning, and the screens are on, they are on the default logo that you get at startup.
This is because although they do appear in L-Connect, they do not hgave the LCD Screen option, so I cannot configure them.
Has anyone else had problems with these fans? I have about a week left to RMA them but I don't think its a hardware fault, it must be software.
They are "wireless" but to make the LCD work they need to be wired into a USB hub, I have a corsair one of those.
I have tried reinstalling windows and just L-Connect with nothing else. No effect. I have checked firmware is latest.
Any help appreciated
