Just noticed this one,it's huge:
ModelTYR PC-X2000 Case
TypeSuper Full Tower Chassis
Dimensions 230 x 430 x 680 ( W, D, H)
Front bezel MaterialAluminum
ColorBlack Side
PanelAluminum Body MaterialAluminum
5.25" drive bay (External)2
3.5" drive bay (External)1
3.5" drive bay (Internal)6 ( SATA Hot Swapable)
Expansion Slot8
MotherboardEATX, CEB, ATX, M-ATX
System Fan (Front)3 x 140mm Ball Bearing Fan ( 800-980-1200RPM, factory set to mid speed)
System Fan (Rear)1 x 140mm Ball Bearing Fan( 800-980-1200RPM, factory set to mid speed); 2 x 80mm Ball Bear Fan ( 1500 RPM)
I/O PortsUSB 2.0 x 2, IEEE 1394 x 1, E-SATA x 1, HD+AC97 Audio
http://www.lian-li.com.tw/v2/en/pro..._index=258&cl_index=1&sc_index=25&ss_index=61
ColorBlack Side
Expansion Slot8
