Lian Li V1000 manual
18 Sep 2006
Anyone know where I can get this for download?
Seems they only have a french version on their site and I want to check a couple of things before I install it.
Not really a manual, just an instructions sheet.
What do you need to know, its all extremely self explanatory really?
If I look in my motherboard manual I'm pretty sure there is no information on which of the case front panel cables (unlabelled) go to which headers on my motherboard. Likewise I'm pretty sure that in my motherboard manual there is no information on the part numbers I need to order for replacing the broken CD cover.
But thanks for your fantastic help anyway.
Calm down man, he was only trying to help, you never posted what your problem was and it could have been for the PSU bracket or blower fan installation.
There is no manual so to speak, just contact Lian Li and they will sort you out with everything.
My headers were not labelled, its not really a big issue and its quite easy just to do 10 seconds and trace them all back.
I can tell you what colour cable is for which header if you like?
No need to be sarcastic. The guy was just trying to help. Can you not trace the cables back to the ports/leds etc that they connect to? As for the CD cover, is theis the part you mean? http://www.lian-li.com/Product/Accessories/Bezel.htm
yeah sorry bad day in the office apologies mate.
it's the actual plastic ends which plug into the mobo which are not labelled and they just go into the a covered cable to the front ports.
I think I'll just plug them in where I think they should go and see what happens :)
I know what you mean about the cables not being labeld, I have an Akasa Fancontrol unit (the 21in1 thing), and it doesn't have them marked as to what is what, but I just kinda guessed and they fitted in the right ones.
Also with the Lian-Li ones I'd have thought that you could trace them back from the front as the others have said, I think I can for my PC7, but then I removed my front bracket for USB etc. as I didn't want it, so I can't remember/check as the bracket and cables are about 150miles away.
If you mean the on button etc. Lian-Li should have marked them (suprised if they didn't really, good make and all), and if not then I think most people on here can help with what goes where.
No worries on the reply, I wasn't sure what you were refering to and we all have day days.
InvG
InvG
Yeah ta mate today's one of the worst, boredom and annoyance everywhere I turn at work :mad:
The front bracket ones are the unlabelled ones and cant be traced back easily as they go into a grey sleeve and then to the ports. Will check again though and maybe cut some of the sleeving away. Think the others are labelled from the power & HD Lights..
Just also wanted to check the parts list (as my case is 2nd hand) and the other info on there also as I am interested really.
