Lian li V1000 plus -fitting bezels...ahhhhhh!!
14 Feb 2006
Having a mare....
couldnt fit my burner in new Lian Li v1000 plus case....so took out couple of front blank plates....no problem...then decided to take out the bezel with the sprung loaded door.....and now I can't get it back in.....how are they supposed to be installed....
the product is shown below.... :confused: :confused:
A picture of bezel
You have to remove all the bezels from from the bottom up, then insert them from the top down.
The only place you can easily insert and take out bezels is the bottom compartment.
Thanks for that....worked ok....
thought this case was supposed to be user friendly ;)
It is if you read the instruction sheet!
Your about the 5th person who has asked this ;)
The reason why they do it is it allows all the panels at the top to be perfectly flush to the front, the other option is having to manually align them all like CD drives :eek:
It works well and is very quick and easy to do :)
(Thats if you read the instructions :p )
