lian li v1000 plus (midi)
Caporegime
18 Oct 2002
Ireland
Thinking of ordering one of these, just wondering though about the space inside. Since its a midi case will the 8800gtx fit inside properly?
Get it! :)
I have a PC101 which is identical inside.
Here's mine with the GTX sat in it:
Plenty of space! :cool:
gt
gt_junkie said:
Get it! :)
gt
I've got to ask...Have you cut out the rear 120mm fan hole? And mounted the fan on the outside of the case....or is it me =/
Hi Delvis,
It had a mesh cover litterally glued to the case. All i did was peel it off and then zip tie it to the outside! Does exactly the same job but allows a little extra space around the chip's heatsink. Don't like cramped workspaces! ;)
gt
