Hmm starting to question wether or not I will fit a 120.3 rad in the top of a V1000 without taking up the PCI slot room, unless I get the rad right to the front of the case within the 5.25" bays. Don't suppose I could send the measurements of my rad to you when I recieve it tomorrow yewen, so you could measure?
Perspex can be heated and bent but I do not know how transparent it will stay. I used a crude way of heating it over a flame and then bending it but it used to become a bit brown over the heated area probably from the soot. Maybe with carefull application of heat in the oven or microwave it will stay transparent.
i was thinking of buying 2 Silverstone Floppy Bezels - Black for me case
so i can have 1 for me floppy drive and 1 for a Lian-Li TR-3B,
i was told if you keep rubbing on the logo with a swettie thumbs the logo will start to wear off
but i wanted to know if the Silverstone Floppy Bezels - Black as the same finish as the LL v1000b finish
