I did think of removing one of the cages but I thought that might not be a good idea as its there for a reason. Also where you remove the metal bit to slide the PSU in, I can't put that back on even if I could fit it in as the part where I connect the Power lead is in the way. Is this a big set-back?
I also red that the Phantom 500 is a lil bit bigger than the 350. I'm wondering if I should return it for a different PSU or if there is some method and safe way around this.
Oh right, the ATX compatible thing you brought up does give me a positive thought then. I will do some more digging with this build tomorrow now though as its 1am.
With my v1100 i had to remove the last panel which sat between the two hard drive cages and the psu compartment and my Enermax Liberty fitted with no real problems - apart from i chose to mount it upside down as when inserted it the correct way up it had the 120mm fan "very" close to the panel above - rendering it nigh on ineffective :/
Other'n that it's all been good !
Great case
