Lian-Li V2010
30 Jun 2004
Just a quick question...
That new V-series of Lian-Li when will it arrive?
Seen a couple of reviews and they look really nice - so I was wondering when we see a pre-order note?
Sorry if it's been asked before... :)
Nice case, but zero gpu or sb/nb cooling. Reckon you'd have to add a kama bay lian li ex-33 to help airflow in an sli or crossfire setup as I don't think negative ariflow from 1 rear exhaust fan will be enough, and the bottom intake is purely for the hardrives.
The support bar is nice as it also has the extra functionality of being able to hang a 120mm fan off it, but a lot of setups with tuniq towers and sli will mean you have to remove the bar anyway making it useless.
The other thing is the drive cages are the same ones on the A70/A71 but are not reversed which means nasty sata cables/power cables will be in plain view. Would prefer if they reversed them so cables would be on right side of case.
