Lian Li V2110
28 Jul 2004
Solihull, Birmingham
I'm looking at replacing my Akasa Eclipse for the Lian Li V2110, how do people rate the Lian Li in comparison? Do PSU's fit ok with the cables (mainly the power cables) reaching the mobo OK?
They do look good to work with, my only worry is if the power cables from the PSU will reach to the mobo
should do willbo - you can always get extensions
plus vseries make it very easy to hide cables behind the mobo tray so an extension wouldnt be noticed
Good to hear...just got to decide whether I can justify replacing my Eclipse with the V2110.
Its either a case of spending money on my Eclipse to accomodate what I've got whilst improving the airflow & cooling, or get a new case which has good airflow & cooling already and sell my eclipse.
One down side to my eclipse is that I've now got 4 HDDs, theyre all installed in the HDD cage which is limiting the airflow into the case.
Whats general airflow like and coolness of the case in comparison with an Eclipse? Would love to hear some opinions
mount your hdd's in the 5'25 bay with sewing machine elastic and buy a kama bay then you can remove the hdd and floppy bays
I get case envy every now and then but at the end of the day if my eclipse is functioning fine I see no point in replacing it
after all I look at my screen not my case.
That is very good reasoning...its hard not to get envy when you have abit of money to the side or see a good offer in the MMs.
You got any pics of your eclipse? interested to see the kama bay in use
Will do later waiting on camera batteries to charge haven't heard a sound from my hard drives since bungee suspending them in the 5'25 bay works very well actually.
Nice one, would be really appreciated to see them mounted....mounting with elastic sure saves on buying the adaptors for mounting there
The adapters actually make vibration worse and sewing machine elastic is like £1 for loads so it's a no brainer
Overal very good case.
Motherboard chamber just has only one exhaust so BS-03 would be preferable addition in case of hot (non exhausting) graphic card.
Also you can't fill all 5.25" bays with opticals/devices because that would block intake of motherboard chamber so ended up getting A71. (it's rare situation when you have non-budget reason for selecting cheaper option)
