Lian Li V3000WX - dust filters and caster wheels
30 Jun 2009
Does anyone know which dust filters and caster wheels would fit V3000WX? I was searching Lian Li's website, but haven't found anything. I know they had some casters in the past, but they're discontinued, even though the case has monting wholes for wheels.
Dust filter - Something like this? (Measure the size you want) Being magnetic you may not be able to use it in that regard but try self adhesive velcro tape to hold it in place if its hidden.
My basket at Overclockers UK:
Total: £25.43 (includes shipping: £3.48)​
Casters - Depending on the case Li-li used 3rd party plate casters or made them for that case. Plate casters may well be the way to go, just drill some holes in the bottom of the case small enough for Self tapping screws or find some that will have the right holes for your case.
