yea its a v300 but its same size as the v350. i think
the v350 as better cooling but i like both cases
if you want to know the real life size i would make a cardboard box from
each of the cases sizes. yea it may sound abit geeky but its what i did befor
i went for my sg01-e
as i just wanted to see how much space it used on my desk
SG01-E
Dimension: 263 mm (W) x 216 mm (H) x 393 mm (D)
PC-V350
Dimensions: 279mm x 262mm x 373mm (W, H, D)
Well if the V350 is the same size as the V300 i think i'll go for the Lian Li v350. I thought it was going to be much bigger as it has 2 120mm fans at the front, i think. Thanks for the pic.
As a side note are there any cheap PSUs that would fit in the v350 (powering an old amd64 939 set up), I'm not sure if cheap and modular would go together would they?
Well my system is just going to need to process HD either from the hard drive or streaming it somehow off my main pc i just need a 939 matx mobo case PSU and a graphics card.
PSU:
again needs to be cheap but i don't want a generic one can someone recommend a cheap modular psu. The other option put my tagan SLi 500W in there and buy a £100 ish modular PSU for my main rig?
Just found my old trusty X850XT. Since it is fairly old would it be worth selling and getting a newer card. I don't think a x850XT can decode HD or am i wrong?
If you want cheap and modular, you buy a none modular and some shrink rap. Work out which cables you need and cut the others off and cover the ends up in shrink rap. There you have it - a PSU without the unwanted cables in the case
lol well i didnt know that from all the images ive seen of the v350 and v300 they look
the same size. i should have checked that befor i said any think
is it possible to fit a 8800gtx in the v300? or v350? i wouldnt mind doing some modifications to the case since the gtx is about 9.5cm in length. but my EK waterblock on the gfx might get in contact with the hdd caging ...
