Lian Li V351 or V352 question
13 Dec 2002
Newcastle upon Tyne
Probably been asked before but was just wondering if a H50 would fit in either of these easily enough? Couldnt seem to find anything that shows one fitted
Thanks
People have had (including me) 120.2 radiators in them before easily enough, so an H50 would be easy. May be worth waiting for the 120.2 CoolIT one though.
Thanks
This is my first rig.
V351R + H50 ... I only got the red one because the other two colours were out of stock. Personally I prefer the simple aluminium look.
http://www.flickr.com/photos/23799372@N02/4787707916/sizes/l/
http://www.flickr.com/photos/23799372@N02/4787076405/sizes/l/
Cables tidy up since.
Yes. it fits and no modification needed at all apart from using bicycle chain to extend the bolt/screw for the radiator fan.
