Lian Li V351
21 Jun 2005
Herefordshire
Hi guys,
I'm thinking of building an sff system around the Lian Li case and am wondering if the nt06 passive cooler will fit into this case?
I will be using a low power AMD proccy and want to make my system as quiet as possible.
I presume there is a little more room inside these cases than the Sugo SG01 or is that not correct.
Thanks for any info..
Thanks for your advice guys, I will put together a mini spec/requirments tonight and hopefully you can find the time to give me some further tips on componants for my build. :)
Hi all, here is my spec so far. The machine is a non gaming machine and I want it to be quiet and run cool. It will have 2 x dell 22" monitors as I work from home a lot and want the extra screen for Citrix (work) while I have the other to do my own thing. Any suggestions or comments are very welcome. :)
Anything marked with a * I already own or will be reusing.
case: lian li v351 black
motherboard: Gigabyte GA-M85M-US2H GeForce 8200 (Socket AM3/AM2+) PCI-Express DDR2 Motherboard
cpu: AMD Athlon x2 5050e 45w *
cpu cooler: SilverStone Nitrogen NT06-E Copper CPU Cooler
psu: Corsair HX 520W ATX Modular
gpu: Matrox Parhelia 128mb * (this runs hot so may switch to a low power Matrox with passive cooling)
soundcard: Terratec EWX 24/96 *
memory: OCZ DDR2 PC2-6400 800MHZ 4GB 2 channel kit *
hd system disk: Western Digital VelociRaptor 150GB
hd storage:Western Digital Caviar Green 1TB SATA-II 32MB Cache
hd backup:Western Digital Caviar Green 1TB SATA-II 32MB Cache
fans:
Noctua NF-P12 Vortex-Control 120mm Quiet Case Fan - 3 Pin (x2 to replace front case fans).
Noctua NF-R8 80mm Silent Case Fan - 3 Pin (to replace front case fan)
Noctua NF-R8 80mm Silent Case Fan - 3 Pin (I will see if there is any room inside to mount an extra fan)
monitor: Dell UltraSharp 2209WA 22" Widescreen x2
keyboard: Logitech diNovo Edge *
mouse: Logitech MX1100 Laser Cordless Mouse *
Asus M4A785D-M Pro AMD 785G looks nice, assuming your CPU socket is AM3or AM2+.
Also i think the mini ninja wont fit on AMD board.
Thanks for the advice. I am edging towards the Gigabyte GA-M85M-US2H after reading too many problems people are having with the microATX boards from Asus. I realise if you search you can usually find problems with anything but once the doubt sets in I usually try something else. :)
Hi guys, I may try a passive cpu cooler first, since the cpu is a low power 45w version.
Any thoughts on a modular psu apart from the one in my spec. Quiet as possible would be good. Who is the current market leader in modular quiet psu's.
Thx
Corsair HX520/620 would be a pretty safe bet. I've had mine for ages now, and although it cost me £100 new, it's probably the best money i've spent.
Brilliant, stable piece of kit. :)
