lian li v352
11 Jan 2005
Birmingham
http://www.pc-max.de/galleries/304/2461?nid=5787
usb 3 connectors.
Dont like it.
I do like it, seems a much better choice for people who use watercooling in them as there is more airflow at the front. not sure about the switch in HDDs and psu though.
looking over it again, psu placement = big win. Means can have big cpu cooler :) (with a dremel :P)
Be nice to see a pic with a rig inside, to gauge size etc
I wonder if having the PSU over the GPU rather than CPU would make temps worse. I like the extra drive bay but you have to slide out the whole motherboard tray to add/remove disks from the look of it unless there's enough width when you remove the fan.
The worst thing about these cases are the screws for the side panels; I immediately replaced mine with thumbscrews (you need to get metric ones such as Lian Li's own as I discovered).
It's good that they're progressing the design, still the best SFF cases for performance setups.
having psu there would help vent heat if anything. A few people did this mod in the v350's to make more room too.
ANd yeah, i rounded my v350's side panel screws so many times :/
Not sure what to make of it. I've been willing Lian Li to make a V352 for ages, now it comes by and its nothing like what I had hoped and seems a bit of a step backwards really.
I'm going to stick with getting a DaBox - should have one in a month.
Saw pics of this quite a while back which helped me to decide firmly on the v351. Lovely case and a lot more stylish :)
Build still in a mess but once it's a bit more tidy, i'll add to the case gallery :P
