Permabanned
- 15 Nov 2011
Here is my build.
PC spec is
WC spec so far
So the build begins. We've seen lots of them so only my layout/progess shots
Gutted!
2X SSD mount under full size optical. I will be marking these and drilling.
The tabs are no longer needed and will be removed!
Magicool Single 180mm Radiator, Phobya Xtreme 200 Radiator, Laying DDC 18W, EK DDC X-RES100CSQ
Plenty of clearance should anyone want to know
Pump & rad combo
180mm rad in place
Just enough space
Both rad (yes upside down)
I'm sending the case off to get some mods. CNC cut for the top rad, CNC a grill for it and then a new bracket in the front.
The plan is the rig can be super silent, small, mobile, lots of power.
Case went off today so will report back soon as possible.
PC spec is
- Intel 3rd Generation Core i7-3770K
- Asus Maximus V Gene
- ASUS GeForce GTX 660 Ti DirectCU II 2GB GDDR5 X2
- Crucial RealSSD M4 256GB X2
- Corsair Professional Series AX860
- Samsung Green 1600Mhz 16GB
- Samsung 224BB 24x DVD Re-Writer
WC spec so far
- Magicool Single 180mm Radiator
- Phobya Xtreme 200 Radiator
- 180mm Silverstone Air Penetrator SST-AP181 X2
- Laying DDC 18W
- EK DDC X-RES100CSQ
Gutted!
Pump & rad combo
180mm rad in place
Just enough space
