** LIAN LI VECTOR V100R MINI **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Gang
Today we have an addition to the Lian Li range in the form of the V100R Vector Mini. The ATX Vector case is a popular option due to the unique design, great airflow performance and cost effective price point.
The Vector Mini builds on that same design ethos with a smaller form factor layout specifically for MATX builds.
With support for up to a 360mm radiator in the top, back connect motherboards, powerful PSUs and high end GPUs, this case offers great value for builders with desk space limitations who still need all the features of a performance case.
Lian Li VECTOR V100R MINI PC Case at a Glance:​
  • Compact case with support for rear-connector Micro-ATX motherboards
  • 415mm GPU clearance to facilitate a high-end graphics card
  • Compatible with modern ATX PSUs up to 200m long
  • Wide range of cooling options with mounting points for nine fans and a large radiator
  • Flexible mounting options for two storage drives
  • Minimise cable clutter using efficient cable management system
I quite like that itx and small builds in general really appeal to me outside of the heat concerns. I don't even know how I'd fit my current stuff in an itx.
If I ever needed a midrange pc though then I'd build one in a flash.
Watercooling and a giant external rad... it's definitely not cheating ;).
