lian-li wheels?
Mine came with some rubber 'slippers' that where a *awfully annoying experience* to get on but they wheels looks black with chrome sides with those, think thats about the best you can get:(
Might want to check out the other Lian Li range i think the square looking case (cant recall the name) has black plastic wheels :confused:
The black wheels are anodised (quite thin in my opinion), I got a set ordered in specially (by the UK seller) to add onto my g50 case :D
I know the store where they imported from too, and I'm sure if you asked the uk company they would order some in the next time they import stuff (usually monthly iirc)
You should allready have the holes pre drilled. they come with black bands that go around the wheels to stop it slipping around on glass etc.
